Trailer size for our new puchase
Marktor
B2301, LA434, BH70, 54" Box Blade, 48" field mower
Mar 24, 2019
Renton, WA
First time user, here. We will be driving a couple hundred miles to pick up our new B2301 with FEL and BH70, plus a 48" rotary mower and 60" box blade. We're trying to figure out the minimum size trailer we will need to haul all that at once. I've looked but can't find overall lengths for the tractor+FEL+BH. Also, could we raise the buckets and slide the implements under them for more compact loading?
Thanks!
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
272
133
catlettsburg, ky
I would suggest a 16’ trailer at the very least. An 18’ would be better.
Tandem axles with brakes.
AllDodge
M9540 RTV1100
Jan 19, 2019
191
South Central, ky
Here is your package on what appears to be a 16 foot trailer and no backhoe, and it takes up the length
https://www.scholtensequipment.com/default.asp?page=xNewInventoryDetail&id=1803580&img=1
With the BH attached, then you may be able to get the bush hog under it but do think your going to need at least a 18 to 20 footer. The same tractor package with a BH
https://www.scholtensequipment.com/default.asp?page=xNewInventoryDetail&id=4965005&img=1
Another thing that will be critical when towing, is it needs to have more weight on the tongue of the trailer then the tail. If weight is not forward enough, then trailer can fish tail
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
I would want at least a 20' tandem for all that. I'd probably stick the mower under the FEL, and the box under the BH, but certainly assess the situation carefully before loading. And lots of binders & straps!
Post up some pix when you get her home.
Glassman13
51
10
Amherst Ohio
I have the same model only its 2017. You'll love this tractor and the things you can accomplish! Mine was delivered to me so not much trailer advice to offer.
leoric
B2650 since 2018. BH77, LA534, Forks, 60" Bucket, 60" Mid mount mower
Mar 13, 2019
76
Indianapolis
I'd highly recommend an 18 foot trailer. 16 foot would probably work but you'll defiantly be hanging off the the back with your mowers. 18 foot is what I found to be the cheapest around since it's such a common car hauler length.
I attached a picture of my b2650 with the backhoe on an 18 foot trailer if you want a reference.
PA452
B2650
Western PA
Is the beaver tail on that trailer 2'?
I've been thinking about upgrading my BX23 to either a B2601 or B2650 TLB and trying to figure out if I could reasonably haul either on my 16' landscape trailer.
leoric
Mar 13, 2019
76
Indianapolis
Yeah it's 16ft + 2ft dove.
3,167
PA452- I can just fit my B2650 TLB on my 16 ft landscape trailer. You have to turn the hoe nearly sideways. I also put some 2x12 cribbing on the trailer deck where the rear wheels of the tractor sit when loaded. This gives me enough height for the backhoe bucket to clear the 2 foot sides on my trailer when I turn the hoe sideways. It's a tight fit, but still works. An 18 foot trailer would work better for sure in order to adjust the tongue weight with the B2650 TLB.
PA452
B2650
Western PA
Interesting, thanks!
ETA: I'm getting into the same questions in two threads, I'll stick to just replying with more in one.
Marktor
Mar 24, 2019
Renton, WA
Very helpful input everyone. Greatly appreciated. I’ll post pictures of the set up once we get figured out and executed. Thanks again!
Utopia Texas
Kubota B2650/Kubota L6060
Jun 14, 2017
110
Brookshire & Cat Spring, Texas
I would go with a 18’ foot trailer. Just because you could fit everything on something smaller does not mean the unit as a whole will be balanced properly. You would be surprised how moving weight on a trailer just one foot forward or back can either make it tow properly or make it a nightmare.
SidecarFlip
Banned
546
My question is. what are you pulling said trailer with?
leoric
Mar 13, 2019
76
Indianapolis
Another thing I didn't mention. I put a weight distribution hitch on my trailer and it greatly helped my 1500 silverado. Getting enough tongue weight without smashing the rear end to the stops was tough. With the distribution system on I don't really have an issue. It was about ~$300 from etrailer.com
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
If you have enough truck I'd suggest a 20' with dove tail. I had a 16' before and not only more room on the 20' but it pulls so much better.
SidecarFlip
Banned
546
I gave up on bumper pulls years ago. I only pull a GN now.
PA452
B2650
Western PA
Was the 16' overloaded or just didn't provide enough space to properly balance the load?
I consider my 16' to be really nice and smooth. I'm giving a little consideration to upgrading to an 18', purely because I'm thinking about upgrading my tractor.
Still not sold on the dovetail. Definitely would make it easier to load tractors, especially with mower decks. But I'm afraid I'll be dragging that dovetail on the ground in places.
PA452
B2650
Western PA
I don't have a dovetail on my 16' trailer. The BX23 can crest the top of the ramp without issue with no mower. Work a mower, I just need to backup up to a slight hill or in a couple of cases I've blocked up the loading gate.
