Just picked up a 2003 ZD28 with 630hrs. I picked it up cheap because the right side will not move. Engine runs well and the left side works. I have read a lot on this site about the problems with the ZD hydraulics, but I have not heard all the solutions. I am planning to do the work myself.
So where should I start, I have read they can need a new charge pump, hydraulic pump, and one or two drive motors which can all addd up to expensive. The following was my thought to start
Remove the hydraulic filter and screen, cut open the filter and see if shavings.
How do I determine if it is the charge pump, hydraulic pump or hydraulic wheel motor. Is there a step by step diagnostic process?
Thanks in advance
Paul
Thanks in advance
Paul
