I was moving some millings this weekend and noticed fluid dripping by the right front wheel. I was in 4WD. Is it a self fix for this shade tree mechanic or off to the Kubota dealer? I've had it since new 16 years ago.- Thanks-Ed
You may get lucky, I did. Mine started leaking because it was building pressure in the axle. Kubota offers a vent kit which replaces the dip stick and it cured my problem.
Even if it doesn't cure your leak it's still a smart purchase to stop future problems.
Kubota number: 35080-99700
By the way, they also offer a dual element air filter kit that's nice as well.
Kubota gives the option to use 90w gear oil. I have changed to gear oil and solved that problem. If the gear oil stars leaking, replace the seal and be on your way.
