Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 08-24-2012   #1
avpowerstn
1st Yr. Apprentice
avpowerstn's Avatar
Equipment: B7200, FORD 545A (cream puff)
Default B7200 Hydraulic Loader Cylinder repair
Hello
I have a 1984 B7200 HST, one of my 1630 loader cylinders is leaking like a sieve. How do I find info on rebuilding this item. Any Info would be nice.
avpowerstn is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-25-2012   #2
Breeze
2nd Yr. Apprentice
Equipment: L3700, Box Grader, 60" Bush Hog, Rear Grader Blade, York Rake, Boom Pole.
Default Re: B7200 Hydraulic Loader Cylinder repair
If it is visibly leaking you have a bad cap seal. Probably you would want to replace the piston seals, same time. Check for any damage to the surface of the piston rod as this will damage new seals.
It is reported that the caps can be a bear to unscrew from the cylinder due to the cap being aluminum and the cylinder, steel. I don't know if this is true with a B7200?
If you have a hydraulic shop anywhere nearby, take it off and have them do the job. By the time you locate factory parts, ship, tear down yourself without the optimal setup and rebuild, the cost will probably be about the same.
Breeze is offline   Reply With Quote
Old 08-26-2012   #3
avpowerstn
1st Yr. Apprentice
avpowerstn's Avatar
Thank You breeze, I know the gentleman I purchased this tractor from, had rebuilt the cylinders himself (11 yrs ago). I believe he said the O-rings were metric? He said the shops wanted quite a bit to rebuild them. So being an engineer, he rebuilt them himself. Now I can't find his telephone number,lol he usually calls me every 6 months or so, But I can not wait that long. At least knowing they screw off is a start, Thank You for the info
Reply
Tags
cylinder rebuild, cylinder repair, hydraulic cylinders, loader leak
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
