Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 10-20-2009   #1
sonofliberty
1st Yr. Apprentice
Equipment: L2800DT w FEL
Default Rebuilding Hydraulic Cylinders on Loader
How difficult is it to rebuild cylinders on loader for my L2350DT. I have one of the aft cylinders that are leaking. The dealer has rebuild the fore cylinders sometime back.
Also, how frequently do they leak?
Thanks.
sonofliberty is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-20-2009   #2
Service Dept Vic
Service Dept Vic's Avatar
Default Re: Rebuilding Hydraulic Cylinders on Loader
They are not difficult to replace the seals and O rings. Usually they leak from nicks or scratches being present on the rod portion of the piston, or from badly contaminated fluid, weak seals, wether deterioration etc.
Keep it clean, take your time.
__________________
Tires, Parts, Tiller Tines and Manuals for North American and Grey Market Kubota/Zennoh Tractors
Oh Ya! We've got that!
Service Dept Vic is offline   Reply With Quote
Old 10-20-2009   #3
Theekillerbee
3rd Yr. Apprentice
Like Vic said, not too hard to do, but use caution and take a few pics when you take it apart. This will help you remember how the seals go back in place. Most cylinders use the chevron style seals, which can be a little tight going back in place. Grease them up real good and it helps.
Another tool to have handy would be an automotive cylinder hone. Put it on an extension and use it to clean up the inside of the cylinder. Many times I've seen cylinders that had little pits in them from water contamination. A hone won't make them go away, but it will smooth them out a little, helping the seals to last a little longer.
Personally I'd find a kit specifically made for your ram. Shouldn't be too hard if it is genuine Kubota. It might be a little more spendy than the aftermarket stuff, but it will fit first time.
Theekillerbee is offline   Reply With Quote
Old 10-20-2009   #4
sonofliberty
1st Yr. Apprentice
Guys,
Thanks for the help. Do you have any pic's or exploded diagrams? Any special tools required?
Thanks again.
Reply
Tags
hydraulic cylinders, l2350 dt, rebuilding
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
