Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 02-06-2011   #1
jd3l88
New Member
Equipment: L245DT with series 1200 loader
Default Re-assembling Hydro Cylinder
Hey everyone,
I'm reassembling the lift cylinder on a model 1200 FEL. I stripped and repainted everything and got rebuild kits because all four cylinders were leaking. So far I did one of the bucket cylinders with no problem, but the lift cylinder is giving me trouble. The repair manual says to install the new V packing into the cylinder head with the lips facing in and then place the washer on top and secure the whole thing with a snap ring. I did all of that, and after I compress the V packing down enough to get the snap ring in the groove it makes it impossible to slide the piston rod into it. I soaked it in hydro fluid too. Anyone have any tricks to get the cylinder head over the piston rod? I already ruined my new paint job and probably a v packing trying to force it, and am going to have to repaint it.
jd3l88 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-06-2011   #2
LRP
2nd Yr. Apprentice
LRP's Avatar
Default Re: Re-assembling Hydro Cylinder
take the packing out , reassemble with the piston rod in place and use oil
when assembleing.
Louis
LRP is offline   Reply With Quote
Old 02-06-2011   #3
jd3l88
New Member
Ok, Took the packing out and slid everything over the piston rod in order. Then put the rod into the cylinder head. I still can't get the snap ring down into the groove. It's real close. I'm using a punch to knock it down into the groove but when I hit one side the other side 180 degrees around the ring starts to raise up. Maybe make a collar out of a piece of pipe to fit the snap ring and use a press? This cylinder is really killing me. Never had one give me trouble like this
Old 02-06-2011   #4
LRP
2nd Yr. Apprentice
LRP's Avatar
your on the right track, u know the old saying,
u can,t have all male pups!!!
Louis
Old 02-15-2011   #5
jd3l88
New Member
Well I fought with it long enough and finally found the answer. The v packings I got from kubota won't fit on that cylinder, they are a fraction of an inch off. A hydraulic repair company we deal with at work came and took a look at it for me and made me a new top bushing for the vee pack a few thousandths shorter. I put it all back together and it fit perfectly. He said it never would have went back together no matter how hard I tried.
Reply
Tags
hydraulic cylinders
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
