Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 03-08-2015   #1
SCVandy
New Member
Equipment: L225
Default Aftermarket hydraulics for loader??
Hi - I have an old L225 Kubota with a loader that I think is the LA844. I've had the hydraulic cylinders repaired in the past to the tune of about $400 and just blew one of the bucket cylinders. The OEM specs are as follows:
Stroke 18.5 in. (469 mm)
Bore 2.17 in. (55 mm)
End-End 29 5/8" (closed) 52 3/8" (open)
Part number is 7J275-64014
I'd like to replace all the cylinders with non-Kubota cylinders, but the two bucket ones first. Since they are an odd size, any suggestions on what to replace them with? These Kubota cylinders are NOT an easy repair like every other one I've seen, so I'm ready to switch them out.
Thanks for any suggestions.
SCVandy is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-08-2015   #2
Tooljunkie
Tooljunkie's Avatar
Equipment: L1501,home built carry all, mini plow blade.
Default Re: Aftermarket hydraulics for loader??
Im thinking if you find anything close you win!
Bore and stroke need to be close,pin diameters are difficult to match, sleeves,bushings new pins -something will have to be made.
May cost as much if you have to pay to machine parts to make cylinders work.
Aftermarket kubota cylinders? Dont know of any but im sure they are out there.
Tooljunkie is offline   Reply With Quote
Old 03-08-2015   #3
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
These guys can make you an exact replacement set.
http://www.baileynet.com/
__________________
Some days you're being chased by the wolves,
Some days you're running with the pack!
North Idaho Wolfman is offline   Reply With Quote
Reply
Tags
aftermarket parts, hydraulic cylinders, loader
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
