B7100 Bolt
Aharrold
B7100 HST
Jan 11, 2015
UK
Hi,
I'm looking for the specification of a bolt used to attach implements onto a B7100, they are found along the side and also fit the front of tractor for attaching ploughs etc.
I know the thread is a fine thread. I'm looking to order in the UK online.
The bolt is 30mm long and about 9mm diameter and has a no7 on the Hex top.
Aharrold
B7100 HST
Jan 11, 2015
UK
Bolts galore!
Think I've found it as an M8x1.25x30
Can anyone clarify this?
Thanks
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Welcome to the forum. A lot of good people here and now there is one more.
volp
Kubota B6001, MF35 with backhoe, Ford 3000, JD LX186 Lawn tractor
Bolts galore!
Thanks
Thats right. Kubota uses metric standard. If you use Tomcats link you will find a parts lists for your tractor. It doesn't give the bolt dimensions but you can use the part number for a Google search and get the dimensions. One of the places is TractorJoe
Anders
cb750k8
B7200HST D 4X4
Aug 23, 2013
101
Dublin, Ireland
Hi
This is not really the answer to your question.
An interesting site for anyone who needs to identify bolts and nuts.
http://pages.cs.wisc.edu/~bolo/workshop/thread.html
You need a Thread Gauge (ebay) and caliper or micrometer.
To really answer your question I took a bolt which looks very like yours (no 7 on the hex head) out of my B7200 and it is 8mm by 1.25mm
Don't know what the 7 means. Could be the grade of steel. If anyone knows or has the Standard I am interested.
Cheers
slowgo
B7100
Nov 16, 2014
17
clinton iowa
my B7100 has 10mmx1.25mm and I have bought them here local at the hardware store, I had to remove the original bolts to get longer ones
kubotasam
Apr 26, 2010
1,200
125
Alfred Maine
I am fairly certain slowgo is correct. 10 x 1.25 mm bolts.
995
As far as the numbers on top of the bolts go ... They are some type of Japanese Automotive torque marking - I have never been able to remember exactly.
I think it is how much to torque the bolt to (in a metric scale) so the workers do not have to think about it too much.
I know it is not the true bolt strength of metric bolts that have a number, decimal point, number (8.8, 10.9)
