CountryBumkin
Mine doesn't raise high enough to get under it with a scraper (it lifts about 4 inches I believe). I can't even see into/under the deck since I have the "mulching kit" there is no discharge flap to lift up to look in there. I could use my garden hose to spray around - but wouldn't be able to see if I got everything.I used to wash out the deck nice and clean. Until it rusted through.
Now, if I mow and the grass is wet, I raise the mower up, and use a plastic scraper to get the clumps off and leave the rest to act as a 'barrier'.
So drive up on ramps or remove the deck sounds like my options.
The idea of using undercoating under the deck to extend its life is good.
I went through about 4 decks on my "Craftsman Tractor" over 15 years because of the wet grass. But I think a lot of the rust was also due to the wet grass sitting on top of the deck too. I want to do a better job preserving this Kubota deck.
