CountryBumkin
I've seen some mowers come with a built-in garden hose attachment so you can run water to the underside of the deck with blades spinning, for cleaning.
Here is a guy that has a drive over sprayer - where he runs the mower while spraying water. http://www.instructables.com/id/Mower-Deck-Spray-Washer/
Is spaying water under the deck with the blades spinning full speed the proper (or acceptable) way to clean the deck?
If yes, would it be worth the effort to install a garden hose attachment fitting (washout fitting)? Such as this http://www.searspartsdirect.com/par...id=SPDxGPROD&gclid=CNecmNTS9cwCFcdehgodqwILLA
