Oil pressure Gauge install B7100
billrigsby
Mar 17, 2015
1,001
136
Florissant CO USA 8213'
www.facebook.com
So thinking this thing through - I placed the old sending unit on the T fitting, the T fitting on the adapter (all with teflon) and THEN inserted into the engine block
Am I missing something, if you needed an adapter to go from where the old sending unit was in the block, to the Tee,
what did you use to put the old sending unit into the Tee if it is 1/8" pipe x three?.
billrigsby
Mar 17, 2015
1,001
136
www.facebook.com
Here is my version of this install.....
Started with the Sunpro CP8093 style line 1.5 inch mini triple gauge set;
Made a gauge housing;
Used this adapter for the oil pressure line / sending unit combo so I could keep the light;
This is the route I went for the water temperature sending unit, albeit temporary,
did not want to experiment with the new Kubota hose. Seems to work fine;
The final install in place and fully functioning;
Also swapped out the incandescent lights for LED lights,
and trashed the poly oil tube and used copper. :)
2,158
Bill,
very nice work !!!
Question - does your T have plenty of room against the metal sides? Or was that not a big deal?
What does your engine run temp wise under a heavy load?
billrigsby
Mar 17, 2015
1,001
136
www.facebook.com
Bill,
very nice work !!!
Not sure what you mean by the metal sides, this was on a 1500 actually not the 7100,
So the only thing I had a problem with putting the T in was I had to grind a little bit off the top of the starter solenoid.
Temps yesterday while mowing a couple of Acres reached about 198
2,158
"Not sure what you mean by the metal sides, this was until 1500 actually not the 7100,
So the only thing I had a problem with putting the T in was I had to grind a little bit off the top of the starter solenoid."
gotcha - I just figured that anything that was a bit longer than the original would be in the way of something else! Seems like you have to measure to see if something is gonna bump into something else!:)
BotaTrac
Kubota B25D, Kubota L305DT, Kubota L2501D, Ford 681 Select-O-Speed
Mar 16, 2017
102
Hogwarts Academy
Sweet install. Looks great - very professional. Gauge's always make me feel like I have more control over things.......
I'm not a control freak - I'm more of a control enthusiast!
Jimc3165
1982 B7100 HST-D
Jul 22, 2015
130
CLEVELAND, GA
After reading this thread several times I purchased the same set of gauges and am installing on my 7100. I asked 85Hokie for some input which has so graciously supplied and am in the process of buttoning up my tractor to do more evaluation on my low pressure issue. I tore it down thinking it was the cam plug and my plug is intact so the oil pressure gauge and temp gauge was needed to trouble shoot.
85Hokie, tried to get back to you yesterday but got an error said your inbox was full. appreciate your input.
Jim
mattwithcats
774
65
FYI,
The 1/8-27 BSPT fitting is the same in Subaru's...
A 300 millimeter hose, with a "T" fitting on the end, is made by LMA Auto Parts.
Has 1/8-27 BSPT on the ends, and a 1/8-28 NPT port on the side
http://www.lmaautoparts.com/products/REMOTE_T-PIECE_KIT_1_8BSPT/
Got mine from Demon Tweaks...
http://www.demon-tweeks.co.uk/motorsport/gauge-pipes-adaptors/lma-oil-pressure-remote-t-piece
Use blue thread locker on the last thread or two...
There are two gauges that I like, the digital three gauge setup,
https://www.amazon.com/Auto-Meter-2391-Autogage-Electric/dp/B00062YW06/
and the single oil pressure gauge
https://www.amazon.com/gp/product/B00062YVW0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
These are digital, no tubes, just a sender and wires....
