PTO question/problem?
firecat
L2501
Sep 24, 2016
Conway Arkansas United States
I have a kubota L2501 with Hydrostatic transmission. The tractor only has 6 hours on it. I hooked up the brush hog yesterday and when i engaged the pto there was grinding of gears and then it goes in. I did have the clutch depressed. I tried it a few times and it would grind just about every time. I unhooked the cutter shaft and engaged the pto and there was no grinding at all, very smooth and quiet. Any ideas?
Thorny
L2501 HST, 4x4, FEL, front snow blade, rotary cutter, box blade
Sep 24, 2016
91
Mountains of CO
sounds like your clutch is dragging. try slowing down the engine speed and pushing the clutch in a few times before moving the PTO lever.
is there supposed to be a certain amount of slack in the clutch linkage?
BCrouse
197
PA
Is the PTO shaft connected correctly on both sides? All bolts tightened? Does it have a slip clutch or sheer bolt?
