pat331
L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
For those of you who wondered how I hooked up my winch to the drawbar, here are pictures of my setup. I bolted the winch to a hitch receiver portable winch mount, mounted the battery to temporary platform bolted to the drawbar, ran a charging wire from the starter to the + side of the battery, hooked a ground wire from the - pole to the tractor body, hooked the + & - winch cables to the battery, and was in business. Yes, I have a snatch block, but the tree I was snaking out was not that heavy and I needed as much line as I could get getting the log out of the bushes. I'd probably snaked out 25 logs or so before the last one hit a stump just right. I've since repaired the winch. As shown in the picture with the double line, the winch has enough power to move the L35 even with the bucket down. Got the winch from a good buddy that didn't need it anymore. Don't use it very often, but when I do, it is HANDY!
