Adding Snow Plow- Switching Hydraulic Line Question?
4,390
That is not a dozer blade. Dozer blades don't have spring trips on them. However, I would doubt that the ground is frozen hard enough in NC to run a plow without skid shoes to keep from ripping up the dirt.
I own a Kubota TG2754, 54" Dozer blade for TG1860 and TG1860G tractors. (That's the writing on the cover)
I also have the operator's and parts manual. It's called, by Kubota, 54" dozer blade and has a spring attached to it!
Apparently some dozer blades can have springs.
Lopez69
B26.laurin cab/64" rear s/b
Mar 25, 2017
Quebec
Hi guys..I have b26 with bt820 BH,..and I'm buying a rear snowblower 64".. now can I add rear remote valve so I can add hydraulics for chute and rotation...in owners manual it states,that a rear 2nd valve can't be used with bt820..,,, any reason why? Thanks..
