B7100 hydraulic block
fender76
B7100HST
May 24, 2017
72
Missouri
Does anyone have an extra, or one on their tractor which is not in use?
My understanding is, that by tapping into this block, pressure will flow to the aux valve, return to the block and then to the 3pt. Can't use both at once but each will work individually.
Is this correct? Roger
5,106
Yes you can use both at once, because the loop of fluid is the same, yes you might get a little hesitation but it will still work. ;)
