Have a GE CR106E000ADA size 3 mag stater controlling a 480 volt irrigation water pump. The coil is not closing contacts. I am only getting 60 volts at the coil and since I have never heard of a 60 volt coil I think this the problem. Line power is correct, 240 volts per leg and 480 volts between legs. I am a bit fuzzy on controls so does anybody have a clue on why I am only getting 60 volts to the coil? I am sure that is the issue, not enough power to the coil to draw in the contacts.
P.S. I think the coil is 120 volts, trying to confirm that.
