L2501 50hr PM Questio
Gorgoth
L2501 HST
Jan 5, 2018
Central Valley California
Hello,
Just completed the 50hr maintenance. My question is on my hst fluid level I’m having a hard time confirming. When I was filling it back up I was careful to watch the sight glass but I never saw it. So I kept filling. Long story short I’m almost at 7 gals of fluid. The required is 6.2gals. I put in a bore scope though the fill hole and the level is definitely above where it should be.(see attached photo) Question is being slightly higher now then the sign glass am I going to damage my tractor if I use it? I turned it on went down my drive way in different gears and articulated the backhoe and FEL and checked the level. It’s still past the sight glass. Any info?
Thank you!!!
Gorgoth
L2501 HST
Jan 5, 2018
Yeah I know I can but the way to drain the fluid has only a large plug on the bottom. Not really a precise way to remove the oil. Plus it’s only me trying to watch and drain.
whitetiger
Nov 20, 2011
2,592
1,102
Kansas City, KS
Drain some from one of the small drain plugs on the final drives.
beaterboss
L3901, LA525-FEL, BMLX-3164 3pt Blower, 72" Coteck Sno Pusher, 60" Box Blade
Feb 20, 2017
152
St.Francois,New Brunswick. Canada
I really disliked the sight glass on my 2501. Sometimes it was right on, sometimes you couldn't see anything. The hydraulic fluid is really clear, and can make it difficult to see most times. When I did my 50 Hr service, I had the same issue, but using my Fluid Evacuator really made correcting the issue easy.
My 3901 has a dipstick, and I much prefer that over the sight glass. I don't know if running it a little over full will damage anything, but I wouldn't chance it.
Stmar
B2650HSDC
May 23, 2017
906
42
Buffalo, Wyoming
Sounds like OP has about a gallon over. How much over is it okay to operate, how precise do you have to be? My B2650 was showing low on the dip stick so I put about a quart or so in and now it is up on the stick to the full mark at times and maybe a little over when hot.
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
428
35
Red Springs, NC
I did the same thing. I was able to take the site glass out and catch the oil in a clean pan and save it. Just be careful when you screw the glass in it is plastic
1,001
Can you use a “turkey baster” to remove the excess fluid?
200mph
Mar 3, 2017
1,228
59
PA
DonDon
L2501
Jan 30, 2018
Brandon, ms
OK, I guess I need to double check things then. I have a what I think a small hydro leaf on my loader. I looked at the spyglass and didn't see fluid. I added 2 full gallons a 1/2 gallon at a time and still didn't see it on the bubble. I thought it would be east to see so I may have overfilled it. Is there a way to check the level besides the spy glass?
lugbolt
ZG127S-54
Oct 15, 2015
4,842
1,591
Mid, South, USA
Easy way. Remove the window, with a drain pan under the tractor. It will drain down until it's at the bottom of the window, then reinstall it. Might have to add a little to bring it back to the middle of the glass.
