B7001D has no power
Grantovsky
Calgary Canada
I have an early 80’s grey market Kubota that has been bulletproof until recently. There seems to be no power when increasing RPMs. When I let the tractor idle in first gear the tractor will slowly crawl. As soon as you hit the gas the tractor stops. Anything above first gear the tractor will not move at all. I’ve changed the fuel filter, bled the lines, still nothing. I’ve cleaned the screen at the base of the transmission and it had little to no debris in it.
I’m looking for the screen/pressure relief under the seat however can’t seem to find it. Does anyone have a picture where it may be located?
Any help appreciated.
5,113
Yep you need to split it and put a clutch in it.
Do a new pressure plate, clutch disk, throw out bearing and pilot bearing.
