Wholly Fungus Humongous
4,853
My L has been down since early July, did the front gear case on the engine, and rebuilt the transmission.:(
Rebuild is now all done, and Wife and I was out running around getting things done when it coughed and sputtered and kicked the bucket... Fired right back up and again minutes later died, well we limped it home and pulled the filter housing and just about puked, slime everywhere! So I cleaned it out and changed filter and it ran great again...till cough, cough, die! I'll be headed to town to get some algaecide and new fuel for it tomorrow.
But hey the trans rebuild was a complete success as it runs and drives just like a new tractor:D ... with algae in the tank!:mad:
b20barry
B20 TLB
Aug 18, 2013
35
Somerset county,Pa
Hi Wolfman, How could you get algae so fast when some can sit for a year and have none. I just don't understand the whole algae thing, I haven't had that problem yet! Don't want to either!
4,853
It's a first for me too! I can only guess that it was working and perking for a while and just the lack of use put it in overdrive. :eek:
CaveCreekRay
Jul 11, 2014
2,631
Cave Creek, AZ
Didn't your mom teach you to wash your hands before re-fueling diesel?
olthumpa
L275
May 25, 2011
1,501
Maine
It is a PITA but luckily an easy and inexpensive one to fix.:)
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,176
117
Coyote Flats,Texas
Algae needs water to grown in diesel IE no water = no algae
2,104
I too have not had the algae problem , nor would i want it !!!!! I think after that fantastic job on the tranny, the engine wants its TLC, cause you are overlooking that poor girl.....:D:D
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Am not an expert!!! Reading on the topic various times it seems "sitting duration" and "growing algae" has a lot to do with how much fuel is in it. A full tank and you get narry a drop of water pulled in. 1/2 tank and less and you get more. AKA.... the more air space in the tank...... the more moisture from air can be absorbed. Also tank sweating which is also from moist air of course.
Also it is actually not "algae" it is a microbial growth.
Bluegill
Jan 11, 2012
1,560
Success Missouri
This summer was the first time I had any problem with it in 30 years. I never actually saw any algae in mine, but changed filter and treated fuel, no more trouble.
4,853
Hey I gave the engine a whole new gear case (timing gear cover) new dip stick, new block heater, water pump, and a lot of TLC, But I think your right, she just needs a little more love... and some Microbial removal! :p
olthumpa
L275
May 25, 2011
1,501
Maine
In thirty one years I have had a minor algae problem :eek: once about 20 years ago. Since then, I treat my bulk tank every time I fill it.:cool: No more problems, no more guessing.:) Some people have told me that I am just wasting $$ treating everything. I reminded them that it is my $$ to wast and. peace of mind is some times priceless.
Oh lest I forget, one of them lost a 40 acre hay field when two of their M135 was down for a day with an algae problem and they could not bail it, then it rained for three days.
Do you think I reminded them why I treat my fuel?:rolleyes:
2,104
How lonnngg was that dipstick ? maybe she didnt like it...........
aw that aint right on soooo many fronts.....:rolleyes:
mendonsy
B7500HST/LA302
May 28, 2012
339
19
Mendon, NY
That sounds very similar to the problems that I had with water in the fuel tank this summer. Must be your water build-up is a healthier environment for algae than mine was. I had a small amount of algae, but not much.
kc8fbl
2014 L3200 HST FEL, 1949 Minneapolis-Moline R
Aug 23, 2012
222
Gobles, MI
There's some fungus among us! :D Maybe practice some safe fuelling. Sounds like the little microbials reproduced more than rabbits! ;) Sounds like you'll be thinning the herd though.
Glad you got your transmission problem fixed and she's just about back in tip top shape again.
2,104
