I'm getting ready to start converting a wooded area to lawn and garden and have been reading about the right combination of implements to use with my BX2380. I've settled on a Piranha bar and a TSC CountyLine subsoiler. The bar is on order but I was able to pick up the subsoiler at my local TSC. Unfortunately the fit is kind of marginal. The subsoiler is almost too wide and tall to fit. To swing the lower arms wide enough I had to lower them way down and tuck the subsoiler under the tractor, barely making it. When I have the arms fully raised I barely have an inch of ground clearance under the bottom of the subsoiler. It fits but when I'm driving around on uneven ground I'm going to drag the subsoiler any time I hit the slightest dip in the ground. I measured 25 inches from the bottom of the subsoiler to the pins for the hitch lower arms.
I read some posts about an earlier version of the subsoiler being kind of light duty, but this ones a beast. The whole thing is made from 1/2 inch bar stock. Unless it turns out to be soft iron there's no way the tractor is going to bother it.
Anyway, has anyone else had trouble fitting a TSC subsoiler? The brand is CountyLine. Looking forward to ripping up some roots.
DC
DC
