Pallet Forks
bruceaub
L3301
Mar 10, 2019
Kouts, In
I’m buying a set of quick attach pallet forks for my L3301. Anyone have any recommendations as to which one, length, weight capacity, etc?
3,208
I recently got a set of these...
https://www.palletforks.com/tractor...-42-pallet-fork-trailer-hitch-attachment.html
Plenty of capacity for what these small tractors are capable of lifting (in fact, they are overkill). I wanted the 2" receiver in the front for moving trailers as well. I believe I got them at a better price, fast/free shipping. Only downside that I have seen thus far is:
1) the welds on the frame look like they were done by a child (and perhaps, they were)
2) my neighbor keeps borrowing them, so they aren't in my possession when I need them
Jchonline
597
Red Feather Lakes, CO
Capacity just over your breakout, 48 inch length, adjustable width if possible. I have the landpride version, they work great.
2,166
Fro65
L3301HST, LA525, BH77, LP tiller, LP grader box, LP blade, BX2380
Dec 30, 2014
220
NorthEast Indiana
I have a L3301 also. Four years ago, I bought the Titan 36 inch version with the crash guard and bale spear socket.
It has been bulletproof. On mine, the welds are very good...I had heard they could be hit or miss. Didn't matter to me because the price was good and I can weld.
Poohbear
Jul 6, 2018
469
132
Gilmer,Tx,United States
I use a Worksaver brand . It's adjustable and no issues with hooking to my QA on my L3301. Quality is top notch.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
I've been happy with the Titans. These are the 42" forks. I just can't spend $8/900 on Artillian or Deere brand. I mean, they're pallet forks.
I only wish I had got the set with a 2" receiver built in. Hindsight is always 20/20.
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
10
IN
My dad and I share 48***8221; Premiers. 4000 lb capacity and well over what I can handle.
It***8217;s nice being able to see the tips from the seat.
3,031
Hayspear.com makes nice forks for all kinds. I'm really pleased with mine.
edritchey
A bunch of cute little Kubotas
Jul 19, 2014
1,075
745
Wellsville, PA
I had a set of forks from Land Pride for a L3901 I used to have they seemed like a nice match they were rated for just over ton and only weighed a few hundred pounds.
shootem604
Apr 23, 2018
875
British Columbia
I have the Titan clamp on forks. I had some welds break, so I reinforced the angles by welding on some angle iron, and no trouble since. Very useful if you don't need them very often, or for very much weight.
Papadiver
BX2380 FEL, MMM, 3rd Valve, Grapple
Feb 10, 2019
87
68
WV
Do you have any idea what the total weight is? This is the set I have been looking at.
shootem604
Apr 23, 2018
875
British Columbia
Yeah, the site says 105lbs for the frame only. Doesn't mention the forks oddly enough.
Papadiver
Feb 10, 2019
87
68
WV
Yep I saw that. I called them today and I was number 45 in line :(. I set a call back but haven’t got a call yet.
cash
9
Pittsburgh
Titan are usually 260lbs and up. Their frames seem to be light, but the forks are very heavy for sub-compacts. For the BX23S and JD 1025r that is a little heavy and better options out there. Probably wouldn't notice on something else heavier though. Artillian prices are crazy and over $1100.
3,208
I would concur with the post above that the frame is somewhere around 100 lbs. The 42" forks are quite heavy (say around 60-70 lbs/fork?). My suggestion for your machine would be to get a shorter fork or perhaps at least some that aren't quite as heavy.
The only drawback to the 42" that I have is that they are rather difficult to see. I find myself standing up to see the tips when they are lowered to the ground. I plan on hitting the tips with some bright orange paint.
Papadiver
Feb 10, 2019
87
68
WV
It sounds a little heavy for my BX. My Ford 1720 would do ok with it but I want one set I can use on both.
