What size pulling chain?
Clover13
220
NJ
What's the best way to spec out a pulling chain for my B2650? Sandy soil, just looking to dig out and pull some small trees and small stumps. Nothing huge, lot of pine with a big taproot and then smaller root systems. A lot I get up and out with the buck and Pirahna toothbar, but for the bigger ones looking to wrap some chain and do a slow pull to loosen up more and then get back to bucket/dig.
Clover13
220
NJ
Very cool! Thanks skeets! I've seen the tire rim trick but that framing approach looks great! I don't think I'll be pulling anything near that big. I was able to bucket out a few with the FEL today after the rain, all sand, super soft...still a bit of work but got them out. I like the subsoiler approach, less of a footprint!
SDT
multiple and various
Apr 15, 2018
3,084
925
SE, IN
A decent 5/16" chain is more than enough.
SDT
Forvols
98
Hawkins county TN
I caught the 5/16in tow chain on sale at HF. it was 19.99 including hooks. Maybe watch and see if Harbor Freight in your area has it on sale (if you have one). I bought 3 of them. Cut one of the 20footers down to 2 10ft ones and bought 2 additional hooks. Ended up with 2 20ft tow chains and 2 10ft chains. for 75bucks..rated I think 4800 or 5400lbs.
Edited to correct: Chain size to 5/16 and over all price to 75bucks. Sorry for the error.
Clover13
220
NJ
Perfect! I have both a HF and TS nearby, so I'll keep an eye on sales and grab some when I get a chance. Probably look into some way to attach some storage to the ROPS or the like as well.
2,167
3/8 x 20' is rather heavy to tote around....
I like a 5/16 - if you break that - you have done something you should not have!
PLUS - 5/16 will bind in a 1/4 hook - and it will bind in 3/8 hooks....
best of both world....
but I do have a 3/8" chain - pull it out only after I have used the other 2 - 5/16's:D;)
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I have a 1/4 chain for light lifting, I also broke it pulling.
I use a hf 5/16 grade 70 for any real pulling or lifting.
Sent from my LGMP260 using Tapatalk
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,128
933
Williamstown Ontario Canada
I was pushing over 20 foot tall pines with the FEL on my M7040.
Was amazed at how easy it was. Failed to realize the stump was rotating out of the ground under my tractor. The angle guard at the front of my fuel tank had one corner ripped free of the fasteners.
Now I either use a ladder or have someone in the bucket connect a tow strap as high up in the tree as possible and then, using a long enough chain connected to the tow strap, pull the tree and stump over.
Dave
3,032
Careful pulling stumps … they can pull that tractor right back over on TOP of you! Pull them by backing the tractor with the chain coming from the 3-point underneath the tractor to the stump.
SDT
Apr 15, 2018
3,084
925
SE, IN
Bingo, Hokie.
A decent 5/16" chain will stop 4 or 5 B2650s, takes up less space and is considerably lighter than 3/8" chain.
For routine work, I use a 1/4" chain.
SDT
torch
Jun 10, 2016
2,593
836
Muskoka, Ont.
Please note the comments mentioning "grade 70". That references the strength of the steel. A gr 70 5/16" chain AND HOOKS will be stronger than an unrated 3/8" chain. Unrated hooks on rated chain (or vise-versa) = unrated.
Jpatrick
BX1850, L210, Various 3 point implements
Apr 4, 2017
100
Buckingham, Pa
I use 5/16 grade 70 chains for skidding logs, pulling stumps, and other tasks, including recovering stuck equipment. Sometimes I've connected as many as 4 chains together to recover distant objects.
If the job is too big, the little tractors run out of traction before they run out of power. Sometimes there's a chance of doing a wheelie. If so, turn around and pull in reverse.
Clover13
220
NJ
Careful pulling stumps ***8230; they can pull that tractor right back over on TOP of you! Pull them by backing the tractor with the chain coming from the 3-point underneath the tractor to the stump.
Yes very good point, some scary videos out there of chains hooked too high. I think as long as I attach it to the drawbar/hitch, it should be good, no?
tiktock
225
Plaistow
I have a "normal" 5'8" chain from way back I use for heavy stuff and in my ammo box on my ROPS i have a 20' section of the orange-painted safety chain HD carries.
4,389
