I got my L3901 a couple of months ago. For my first mod, I decided to add some chain hooks and Clevis mounts to the bucket. After doing some research on the web, I decided to go with Ken’s Bolt on Hooks. I ordered three chain hooks and two Clevis mounts.
My bucket has an extra piece of steel welded across the top, which is perfect for mounting everything. The only issue is the top lip of the actual bucket doesn’t meet up with the back edge of the top plate, so you end up with an uneven seam right where the bolts holes are located. This makes for an uneven surface for bolting everything together.
A quick email to Ken got my problem solved in no time. He sent me (For no charge!) a set of spacers that filled the gap between the two layers of the bucket and these allowed for a level surface to tighten down the bolts.
Here is everything installed:
I can’t say enough good things about Ken and his products and customer service!
