box or scraper blade?
abolt300mag
BX2380 60" MMM FEL Landpride 54" grapple LP 1248 box blade
Feb 21, 2019
14
Middletown De
I have a section of woods that I am cleaning out of debris, undergrowth and small to medium rocks and want to level the ground to some degree by filling in holes and such. I have a bx2380 w/fel & grapple. I would appreciate some advise/thoughts on my next purchase for this task which will then also be used for what ever else... box blade or scraper blade?
2,104
box does wonders on un-level ground - great for getting high spots to low spots
poor for anything else like moving from left to right.
Rear blade - excellent for moving left to right....not a great cutting device.
For what you explained the BOX wins. - it has the teeth (scarifiers) that will cut into the soil and allow dirt to be picked up and moved.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
I bought a blade because that's all I had every been around. After I bought a box blade I've never used the blade again. And to put a time line on that it's been sitting in my shed unused for over 20 years.
abolt300mag
Feb 21, 2019
14
Middletown De
See that's kinda where I am at, all I have ever owned is a scraper(no longer own) and have only used a box once that I borrowed, neither of which were in similar areas of use(in the woods)
abolt300mag
Feb 21, 2019
14
Middletown De
I took the advise given and purchased a LP 12 box blade, went with the 48" for clearance in the woods, thanks for your responses
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
I have used my Box Blade for moving a lot of dirt and spreading out gravel. Works great for those types of applications.
Papadiver
BX2380 FEL, MMM, 3rd Valve, Grapple
Feb 10, 2019
87
68
WV
I have a box blade for my Ford 1720 and that’s all I use on the gravel roads. I may get 4’ for my new BX
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
I bought a box blade and a hydraulic angle blade. I have built a mile long bush road in my back yard where I harvest firewood.
When I start building the road I put on my angle blade the first day. Took it off and never put it back on. I use the box blade for everything.
Once you get some seat time and get to know how to set your lift arms and top link to get different cuts and slopes you will be very happy with the box.
Only thing I ever use the angle blade for now is maybe one time in the spring when the snow starts melting, I will use it to cut the base off the driveway so I can wing it off to the sides.
Hidalgo
MX5800 LP 6' Bushhog + Boxblade, 12" auger, broad seeder, hay spear
Feb 15, 2019
Carthage
I hope thr box blade was all you hoped for and more :)
I love mine to maintain our driveway and riding arena but still need a scraper to move the arena dirt from the outer edge back to the inside.
Did you try the box yet?
Alderman
42
New to Kubota life with a used 1870.
I purchased a 40 acre woodlot that was logged over a few years ago. Due to gaining access issues, the previous owner had a dirt road punched in to gain access to the top section.
Between the rain and the elk, the road gets rutted up quite a bit.
My 1870 came with a 48” rear blade. I tried it out for smoothing the road but it wouldn’t get a good bite.
I took a chance on a 54” box scraper and just got it mounted this morning.
Went up just to play around a bit and after some adjustment was able to get the front blade taking a decent bite.
Didn’t have any rippers down and want to wait for it to dry some before I really get after it.
First impressions are the box scraper will be the better of the two for doing what I want.
pauly
2014 B2650, LA534A FEL,B2781B Snow Blower, Land Pride RCR 1260 Land Pride RB157
Sep 23, 2014
150
East Troy Wisconsin USA
You’ll find the box blade very usefull for many jobs. I kept my rear blade for light snow. Have a box blade for maintaining a quarter mile gravel drive. I also use a land plane for touching up the drive. All usefull tools.
abolt300mag
Feb 21, 2019
14
Middletown De
yesterday I had the opportunity to use my new bb1248 box blade. must say I am very pleased. thanks for all those who responded and helped guide me to the box blade
