Will a BX2750C snowblower play nice with a BX1500?
reamer
B2400, BX1500
Jun 6, 2018
54
Ashford CT
I know they say "compatible with all BX tractors" but in actuality are they?
I know with the "BX quick hitch" there is one only for the BX1500, this rests on the frame and secures with a large "T" screw and every other series BX uses a different type that "bolts" on....
Is the BX 2750C snowblower too much for a 1500?
if it is, what model is for a 1500?
Thanks.
5,106
Yes the BX1500 was factory equipped with a BX2750.
So Yes it's compatible.
5,106
Simply put, they are improvements in design.
So yes you want the C version.
Charlie5320
BX2670
Jan 8, 2018
114
9
Springfield, IL.
Thanks.
My Bx2670 doesn't bolt on. It has a T handle and 2 pins through the bottom. No bolts to install it.
