My updates on B2650 with Cab
BX25D KY
BX25D
Sep 26, 2015
Ky.
Mr D
Mowing
Feb 9, 2017
31
Columbia City, IN.
Where did you get those clevis hooks? I would like to get 2 for my bucket. I can't find any that are turned like those. I need them to be strap hooks instead of for chain. Nice job on mods.
Thanks
I Bought the hook from TSC then altered it
To fit my needs
Thank you
BruceK
NY
I'm interested in how you wired the light for the E-brake. What did you use and what switch did you tie into or added. Plus how you routed the wiring.
200mph
Mar 3, 2017
1,228
59
PA
If your interested in color coded hydraulic dust caps, you local Kubota dealer might have them for some of the other applications.
Of course colored electrical tape also works in identifying which line is which when swapping implements.
Mr D
Mowing
Feb 9, 2017
31
Columbia City, IN.
I Bought a mechanical switch and mounting it to the firewall, when you set the bbreak it trips the switch to turn on the brake light
Thanks
wacnstac
loader, forks, box blade, disc
Apr 3, 2018
60
Wellston, MI
What is the part number or type of switch you used? I would imagine that since the 3350 has that feature, there might be a Kubota part out there.
Mr D
Mowing
Feb 9, 2017
31
Columbia City, IN.
That’s a great idea, but got the from Amazon
I will need to look for the part # on the switch and light
Thanks
Mr D
Mowing
Feb 9, 2017
31
Columbia City, IN.
Thanks
The light is, universal motorcycle bike red led tail light
Sorry I cannot find the switch
Thanks
Firefox
2650 hst cab,fel,72mmm,48lp forks,48 tiller,PeCo vac,wt box
Mar 15, 2018
30
Swanton ,Oh
Nice job on the updates. I'm going to put that e-brake lite on my to-do list.
Duke
2018 Kubota B2650 HDSC with FEL and 72â€￾ rear blade.
Jul 29, 2014
31
Metamora, MI
The B2650 already has a parking brake switch installed the same as the B3350.
The difference is there is no indicator light on dash panel for the 2650 and there is on the 3350.
Why Kubota omitted the light on the 2650 is a mystery.
The switch is still used for safety circuit control.
You can remove the dash cowling by removing 1 phillips head screw located below and center of the top storage pocket and loosening the 2 10mm screws at the bottom and each side. You'll see the switch is activated by pressing the brake pedals.
