Randyj
B9200D / BF350 Kubota Loader / L-4530B Kubota Backhoe w - subframe / LP GS1548
I bought my B9200 a few months ago knowing the previous owners beat the living daylights out of it. It ran, although ruff ( has a miss on acceleration).
Starts very hard. But starts.
Well, it USED to start !
That miss has been driving me nuts, so, I decided to pull the injectors to have a look. They were dirty, and covered with black carbon deposit. I dismantled them and cleaned everything up with brake cleaner and a brass brush. The needle assembly on all looked pretty good under a magnifier.
When I removed the hard fuel lines I decided to also remove the delivery
valve's from the top of the injector pump. There was some small pieces
of dirt down in the bore of each, so I cleaned that out as best as I could.
Well, now, the engine won't start ! Part of the reason for the hard starting
before was because the starter had a couple armature windings seperate.
I found this out after I reassembled everything & tried to fire it up. The starter was really dragging, even with me "jumping" it with my truck. That's when I pulled the starter off, dismantled it. and discovered the toasted armature! I bought a new starter and now the engine cranks over like crazy!
Only it won't start! Lot's of black smoke, though.
Tonight, I pulled the lines off & cranked it over. The delivery ports on each end, or for number 1 & 4 clyinder's, are sperting fuel up about 1 1/2 - 2".
Nothing from the two ports in the center.
New injector pump is over $900.00.
Are these pumps serviceable by meer mortals ?
Any thoughts are welcome. I'm a desperate man at this point!
