My MX5200 doesn’t have much power in the curl but seams to be fine on lifting. If I put the bucket flat on the ground and curl the bucket on the dump circuit it very slowly starts to lift the front of the tractor then runs out of steam half way through its stroke. If I curl the bucket all the way in the dump position then lower the bucket to the ground and try to curl up it won’t move at all. It used to have no problem lifting the tractor off the ground in either curl direction. Fluid level if fine.
Any ideas what might be the problem.?
Thanks.
Thanks.
