4 in 1 Bucket
Hughski
B2650
Mar 20, 2019
Placerville, Ca, US
Newbie here, I am purchasing a new Kabota 2650 and want to get the Kubota 4 in one bucket. Dealer says it’s a little heavy, that I should be careful. I looked at the different it’s 130 pounds more than the standard bucket. She stated she’s gonna look to see if the gear more four in one bucket is less weight. Can I get some insight from you guys please??
Thanks
SDT
multiple and various
Apr 15, 2018
3,084
923
SE, IN
Thanks
I bought a 4 in 1 bucket with my L6060.
The 4 in 1 bucket weighs at least twice as much as does the standard material bucket, resulting in a loss of payload.
I find little use for my 4 in 1 bucket. The only times that I have used it is to avoid installing the grapple on my M9960 to move a (not too heavy) log or two.
Do you have a need for it?
SDT
Hughski
B2650
Mar 20, 2019
Placerville, Ca, US
SDT
Yes and no is the answer. I wanted it to use as the dozer style work as well as moving material and brush.
What I was worried about is loss of payload! May just need to pick up a grapple.
Hughski
B2650
Mar 20, 2019
Placerville, Ca, US
One item I noticed is the specs
3901 with the LA525
Lift capacity (pivot pin) is 1131 lbs (513 Kg)
Lift capacity (500 mm forward) is 855 lbs (388 Kg)
2650 with the LA534A
Lift capacity (pivot pin) is 1146 lbs (520 Kg)
Lift capacity (500 mm forward) is 827 lbs (375 kg)
So this makes me wonder why it was ok on the 3901 but not the 2650?
BigG
Sep 14, 2018
1,950
774
West Central,FL
Thanks
I would buy the standard bucket and look at one of the grapples that bolt onto your bucket. I have had one for 14 years. They do not weigh very much and it saves the payload. And using the loader as a bulldozer is not the best use for the loader I would get either a box blade, first choice, or a scraper blade on the 3 point
5,062
Thanks
Yea a 4 in 1 bucket from any a manufacturer is going to be heavy, and you will loose a lot of lift using one on that tractor. ;)
Hughski
B2650
Mar 20, 2019
Placerville, Ca, US
Yea that is what I am thinking. May be a blessing in disguise.
Now the Chore of picking a Grapple!!!
Land Pride is pricey and doesn't look as sturdy as some others!!
Thanks Everyone. Grapple ideas would be appreciated.
Jchonline
597
Red Feather Lakes, CO
I agree on the 4 in 1. Also good luck using the tractor as a bull dozer.....it just isnt heavy enough to push much dirt.
For Grapples look at EverythingAttachments.com, they are the best balance of value and quality in my opinion. Others may have more suggestions.
fruitcakesa
M 6040
Oct 26, 2010
852
265
Cavendish Vermont
I just bought one of these,"the Thumb", and mounted it on my pallet forks.
Seems well made and functional and it only weighs about 100 lbs for the 36inch model so it does not lower your lift capacity much.
SDT
Apr 15, 2018
3,084
923
SE, IN
That's what I would do.
Get the material bucket and put the saved money toward a (not too heavy) grapple.
SDT
Hughski
B2650
Mar 20, 2019
Placerville, Ca, US
Thank you everyone. I like your input and have decided to get a EA root Grapple and a regular bucket. Hopefully Shipping won't be to much to California!
