L200 Ring gear and flywheel bolts
Jake WC
Kubota L200, Kubota ZD21
Mar 20, 2019
Perkasie
Working on an early model Kubota L200. Need to replace the flywheel ring gear Kubota p/n 15103-63821 OR the flywheel assembly Kubota p/n 15211-25011. Also need (3) flywheel bolts Kubota p/n 15103-25160, they are dia. 12mm X pitch 1mm X 60mm long. All dealers I've tried tell me these parts have been discontinued. Used is acceptable if ring gear is in good condition and flywheel can be resurfaced if necessary.
