I just purchased a 2011 BX25 with 105 hours on it. It is very slow in reverse in both high and low range. The tractor seems to be straining to move. Both forward ranges seem to be ok. The filter was changed at 76 hours by previous owner. The fluid was low and not reading on the dipstick. I added about 2 quarts and it is now in the safe range. Reverse is still slow. I have not adjusted the pedal yet but it seems there is only about an 1/8 inch to go. Manual on page 32 says not to adjust stopper bolts, serious damage to the HST so I left it alone. Any ideas what could be wrong. Or should I try to adjust the stopper bolt for the reverse function. All other funtions of the loader and backhoe seem to work normally. Pictures attached are of the stop bolts. Closeup photo is of rear bolt.
Update!!!!! its fixed thanks for all the great advice. not
