I have an L3830 2006 HST with a BH 90 backhoe. The backhoe is plumbed on a separate line from the power beyond as it should be. The problem is that if I use the rear remotes with the backhoe connected the pressure blows out the seals in the backhoe valves. I tried my wood splitter hooked into the backhoe circuit and when I used the remotes it extended the splitter head. The Kubota dealer has no idea what the problem is, but they put a pressure gauge in the backhoe line and sure enough they recorded a high pressure reading when the rear remotes were activated. I have had this issue since the tractor was new and nobody seems to know what the problem is. Thought I would post it to see if anyone else has had a similar experience. When I use the backhoe I do not use the rear remote and when using the rear remote I disconnect the backhoe line and this seems to work okay.
Thank-you
Thank-you
