I was using the tractor earlier today and went to shift from 4th to 5th gear and the clutch was very slow to grab. When it did it wouldn't hold when going up a slight incline. However, when put in reverse it had no issue when in 5th gear or higher.
My real question is how do I determine whether I have a wet clutch or a dry clutch. From what I read, the gst's have both a mechanical clutch and hydraulic clutch. I'm trying to determine whether I'm in it for the less expensive fix of the mechanical clutch or the more expensive fix of the hydro clutch.
Of course I could be completely off course and haven't read enough.
Tractor has over 2300 hours on and from what I know the clutch has already been replaced, but I do not know what the hour count was on the previous clutch when it was replaced and I've only put about 40 hours on it since I took possession of it back in March.
As always thank you in advance for the help and guidance!
