Green machine The Thumb
melvinhatcher
L3301HST, LA525FEL, 66" QA BUCKET, L8455CRUISE CONTROL KIT, WR LONG 3RD FUNCITIO
Feb 16, 2016
192
Edgewood Maryland
I have a L2256 bucket, that I would like to install the Thumb by http://www.greens-machine.com/index.html
Greeen's Machine Shop.
Anyone here done this installation on theL2256 bucket? Should I drill holes in the top edge of the bucket and bolt it on, or weld on a bracket to bolt it too. At any rate, I can post some pictures. I have it C-Clamped in position now just for a trial fit.
PHPaul
Apr 2, 2015
958
807
Downeast Maine
www.eastovershoe.com
On my B2650 and LA534 bucket, I made a bolt-on mount by welding nuts to the back of a piece of bar stock and cutting holes in the back edge of the bucket so it sat flush and then welded the mount to the bucket.
Did the same thing to my forks so I can bolt the grapple to either implement in a matter of minutes.
Another advantage is that when the grapple isn't on the bucket, I bolt a hook and D-ring mount in it's place for lifting.
scdeerslayer
MX5200DT
May 23, 2016
434
SC
If you have a thick plate at the top of the bucket I'd just weld to that. That's my plan when I get around to getting one. The plate on mine is about 3/8" thick. I hook my chain grab hooks on it all the time to pull with and it hasn't budged at all so it's got to be plenty strong. Without doing something like the post above I think it would be kind of tough to bolt it on mine.
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
How thick is your bar stock support plate, and what size and grade bolts did you use?
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
Sorry about the pictures that were too large, second try, I hope this time I will do better.
I am waiting for the drill bit that I ordered to drill the holes in the bucket and finish my project.
I have somewhat of an overbite with the grapple. In the opinion of the populace, do you guys think an overbite, under-bite, or pinch on the edge of the bucket, is preferable?
I think I might add a shim under the grapple's base to correct the overbite.
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
40
KY
It appears from the view in the third picture that I have somewhat of an overbite with the grapple. In the opinion of the populaces, do you guys think an overbite, under-bite, or pinch on the edge of the bucket, is preferable?
Have you finished installing your thumb? I'd like to hear feedback on it. Which size did you get?
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
Hello Matt,
No sir, I have not finished my thumb installation. I lost two trees in my yard due to the wind therefore; I spent my last few warm days cutting them up thus putting the thumb on the back burner. Now that it has turned cold, all outside work will be on the back burner, as it warms back up, I will get back to my thumb installation.
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
Well, I have a preliminary installation. I need to do some final adjustment to get the bucket bite even with the thumb tip.
MattN03
Sep 5, 2016
222
40
KY
Nice! Have you had a chance to run the grapple?
BAP
Dec 31, 2012
2,531
670
I have one on my B2920 and love it. I use it all the time moving brush and wood.
BAP
Dec 31, 2012
2,531
670
I don’t use any lube. I take mine off and on depending on what I am doing with the bucket. The amount that I use, it would take a long time to wear much.
melvinhatcher
Feb 16, 2016
192
Edgewood Maryland
:) I will probably do the same, because I plan to use mine between the bucket and my forks. :)
