Hello all:
I am the happy new owner of a L3901 after a week of rather intensive research and driving back and forth between green and orange dealers which are in two different towns in opposite directions from our home.
We have about 5 acres that needs a fair amount of work for snow removal, brush and tree clearing, driveway repair, pad for a shop, and more things I haven't thought of yet. I have used a few very beat up tractors in the past but never owned one.
With the tractor I am getting the Loader, PFL2042 loader forks, the BB1566 box blade and RCR1860 brush mower. The tires are being changed to the industrial tread. The dealer is installing the canopy, filling the tires, mounting chain hooks on the bucket, and installing a block heater. The dealer has been excellent.
For the logic of the tractor choice we were comparing to the green 2038R, 3038E and 3033/9R vs the L33/3901 and L3560. The 3R's and L60 were quite a bit over the budget and my wife and I both preferred the L3901 to the others (and it was cheaper!). I thought for the price the power upgrade from L3301 was an easy choice and the dealer thought correctly we would never use many of the features in the L60 series. We were able to see and test drive all of the tractors except the L60. There were a few near new tractors available but I didn't find the price compelling vs new. Key features that sold us on the L3901 I think were the 3 speed HST, and generally a smoother feel operating the hydraulics and tractor itself which convinced us this was the best value.
It will be a week or two until it's delivered since the canopy and one of the attachments had to be ordered. In the meantime I had a couple questions and would welcome any suggestions or comments...
Is the quick hitch setup going to be worth the cost? I envision the box blade and loader being mounted most of the time with maybe half a dozen escapades per year with the mower attacking the weeds and bushes. The dealer thought it was not necessary.
Is the 1566 (66 inches wide) box blade too big for the tractor? The online manual lists the maximum width as 52 inches but the dealer recommended going wider to cover the width of the tractor.
I believe the 60 inch bush mower with the clutch rather than sheer pins was probably a good choice. IIRC the 48 inch ones used sheer pins which may not be a good choice given the operators lack of experience while the 72 inch wide may be too much especially given fairly uneven terrain. With these constraints is the 60 inch mower going to be just right?
I have read several posts about adding teeth (more like dentures) to the loader bucket -- will these work with the stock bucket? Is there a land-pride version or is the best one available from another manufacturer? I am in a continual battle with Saskatoon bushes and if there is something good at ripping them out that would be wonderful.
Is the there any other implement or accessory I should consider or anything I should know about the tractor or the implements I have listed above?
Thanks in advance...
