L3200 Hydraulic Flow
mkc1962
2012 L3200
May 17, 2011
64
Valley Grande, Alabama
Does anyone out there happen to know the Hydraulic flow capacity of an L3200?
Looking at adding remote hydraulics to my L3200 and find kits that are for 1 of 2 range hydraulic systems those below 15gpm and those above.
Thanks for any feedback.
200mph
Mar 3, 2017
1,228
58
PA
Found this in the wholegoods listing.
L3200DT
DIESEL ENGINE Model #D1503 3 Cyl. 91.5 cu. in. + 30.4 Net Eng. HP + 26.7 PTO HP @ 2800 Eng. rpm Interim Tier IV Engine Indirect Injection (E-TVCS) 12V - 490 CCA Battery Charging Output 40 Amps Electric Key Shut-off
HYDRAULICS Open Center — Gear Type Single Pump 6.5 gpm Remote/3 Pt. Hitch 4.0 gpm for Power Steering 10.5 Total gpm Cat I 3-point Hitch At lift Point 1998 lbs. 24” Behind 1435 lbs.
Hope this is what you were looking for.
mkc1962
2012 L3200
May 17, 2011
64
Thanks for the continued replies.
Now that I have the flow info, I know what range of controls to spec, However was looking at an electric over hydraulic approach rather than an added Control stick. I just have not decided which route to go on that. I did another post looking for overall opinions on either 3rd function or splitting.
