cylinder sticks/stops
tims
9540 L48
Feb 26, 2013
26
DeMotte In
When running equipment in back of our 9540 the hydraulic cylinder will bind up/ stop in one direction, but not the other, when bringing up or letting down equipment. If I raise it all the way up and the let it down slowly it will work. Have 2 sets of outlets and I'm pretty sure it does the same on both sets. Haven't used the other set this year. Using it on a 10' disc, 4 bottom plow and a rowse scraper.
Thnx
Tim
Tooljunkie
May 13, 2014
4,150
27
Perhaps the couplers arent properly seated. Or they arent connected to the corresponding ports. One above the other,not side by each.
It has been done before,and hydraulics function,just not correctly.
tims
9540 L48
Feb 26, 2013
26
DeMotte In
If I understand you correctly, on a 2 hose system I should put one in each tier of ports?
Thnx
Tim
5,113
What Tooljunkie is saying is that are you sure you are using the same matching remote ports / outlets?
If there is 4, 2 are a pair for one remote function valve and 2 are a pair for the other remote function valve.
The other issue might be in a bad Quick disconnect fitting which is not allowing fluid to flow properly, and if it's doing it on both remote connections then It's on the implement side. ;)
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
531
81
Mount Vernon, Ohio
Ditto what Wolfman said. Chased a problem on a 1 year old 1590 JD no-till drill for a week one time just to discover it was a bad coupler. It'd be rare to have a bad one on each pair of remotes though.
tims
9540 L48
Feb 26, 2013
26
DeMotte In
Don't have another tractor to hook it up, but it also happens on another implement. I will try changing out the coupler
Thnx
Tims
tims
9540 L48
Feb 26, 2013
26
DeMotte In
Is there a difference between a "Poppet" tip and a "Ball" tip that might cause a probelem?
thnx Tims
tims
9540 L48
Feb 26, 2013
26
DeMotte In
Figured out the problem. The Female hydraulic connection on the back of the tractor is poppet design. The male end on the hoses on the were "Ball type". Everything I read I interpreted to mean "Ball and poppet are interchangable". I tried changing the ball hose ends to poppet and everything works great.
thnx Tims
