Hey guys,
Its been quite awhile since I've been on here (been busy trying to build an addition). I have a L275 4 wheel drive tractor that I'd like to get back to working on.
The first issue was that the 4wd was not working. I have since found out that right side mechanics behind the wheel are shot. (The seal leaked on the PO and it was never replaced and......) SO, does anyone know where to get parts or what other tractor they may have been used on?
The second issue is the hydraulics on the loader. It lifts slowly and can't lift much. I have replaced the pump, checked the pressures at the port under the seat (they meet spec). Now what? Following procedure in the manual, there is a little tab on the 3pt lever that you move out of the way to do the pressure test. If I raise the bucket with this tab moved, the bucket flies up but won't go down. So what does that little bit of extra throw on the level do?
Thanks,
Josh
Thanks,
Josh
