A farmer friend put a couple led lamps in roof of his tractor. Amazing!!inexpensive and take little power to run. Lights up 1/2mile because they so high.
Sheep,I am wondering if it would work ok to hook an LED light bar as in the links above up to a separate 12 volt car battery stashed (neatly in some kind of box) behind the seat? The reason for this inelegant solution is that I don't want to touch one electron of the Kubota's system while it is under warrantee and given all its fancy computer stuff. Also I don't plan on too much after dark work, but just occasional finishing up of projects, so it wouldn't require a lot of recharging.
Thank you , ben , im going to try to figure out best way to mount them.
Thx, 85 hokie, any idea how to mount them on the roof ? is their a bracket that can be ordered that fits on 9540 or do i need to fabricate something ?Steve,
for the price of the lights and the light that is provided - this is a good bargain.
http://www.amazon.com/SHANREN-water...425043775&sr=8-1&keywords=led+off+road+lights
The do not come with all the fancy hardware - but I am sure you can be creative and find a way/place to mount them!![]()
thx any idea how to mount these lights on the roof, is their a standard mount available ?LED, LED, LED, LED!!
Spots, spot floods, single or double row light bars, front. back-as many as you can find room to mount!
Look for units that are IP67 or 68 compliant (means dust, insects, field debris, water/condensate can't migrate into the housing)
A 3 Watt LED light will generate such an abundance of light it will "amaze you", a 5 Watt version will blind you!
Forget everything you think you know about wattage in the cottage! LED's have little to no load, will last forever, emit continuous white light without fixture shadow or dead spots, are not subject to flicker caused from varying electrical output or vibration and are relatively inexpensive.
Don't worry about which manufacturer made the LED in the light you settle on (CREE, Epistar, Osram) they're very much on the same in terms of lumens, heat dissipation and circuit board technology contained in the housing.
In terms of brands, there are so many good quality "house brands" out there now all offering a relatively similar quality that paying more for a Rigid Industries or Vision-X doesn't make sense and your wife won't approve of you paying more than necessary for lights anyway!!
Look more for a light that feels "solid" and one that offers flexibility in mounting.
After you install some, post back some pictures of your tractor and don't forget to post one of yourself; it will be the one where your Kubota is in the background with the lights illuminating an area the size of an airfield with you in the foreground two thumbs up with a huge grin on your face!
Ohhhhhhhhh ya!
LED lights on your Kubota; does it get any better?
Kubota Fan,What do you guys think about these? Found these while looking for lights for my BX purchase.
http://www.amazon.com/Light-Lights-Waterproof-10v-30v-Offroad/dp/B00RV83UUG/ref=pd_bxgy_auto_text_z
Your welcome and I'm looking forward to your feedback.Kubota Fan,
Thank you, this is excactly what i was looking for. I just ordered two units one for 1100c and one for 9540, ill get them installed let you know how they work !
