L3400HST won't start after fuel line bleeding
5,056
Are you 100% sure its a bad connection?
A bad relay will cause erratic operations. ;)
Hai
Kubota L3400 HST
Mar 2, 2014
61
You have a good point. Can the relay be erratic if I can hear a small click from the replay coming from behind the dashboard each time the key turned to on, especially when the fuel solenoid did not kick in with a louder click. Is there a way to test the relay? Thanks.
