NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
I finished my mid pto gear case replacement. (piks to come when I get this new problem resolved) All was well until I filled everything back up with SUDT.
On the left hand side of the mid pto shaft there is an HST suction filter "HH670-37710." It keeps leaking. I tightened it by hand as much as I physically could muster.
I thought maybe something was defective with the filter and I have a spare so I swapped it out. I cleaned where it gets screwed in to the max, everything looked good. Now the second new filter, still leaks. I went to napa and bought a cap style filter and used my ratchet to tighten it up even more.
Still leaking.
Here's a shot of my first replaced filter top. I screwed it on so tight the metal started to scrape. I guess I can remove it and take a picture so you guys can check it out but I have to run out for a few hours.
What gives!? I just poured four gallons of SUDT fluid in there. I'm beyond frustrated.
Still leaking.
