Quick Hitch installation
Poohbear
Jul 6, 2018
469
132
Gilmer,Tx,United States
No Poohbear, my PTO was cut to fit my tractor and roto-tiller prior to me installing the quick hitch. The hitch moves the tiller approximately 4***8221; rearward which makes the shaft a little bit short.
So the shafts have been cut prior to adding the quick hitch is what I am reading. If so you will need to get a longer PTO shaft. Doesn't Tractor Supply sale the shafts ?
As I said, no problem with a Kubota QH & LP mower.
melvinhatcher
L3301HST, LA525FEL, 66" QA BUCKET, L8455CRUISE CONTROL KIT, WR LONG 3RD FUNCITIO
Feb 16, 2016
192
Edgewood Maryland
Yes, but a PTO adapter is much cheaper than a new PTO shaft.
BAP
Dec 31, 2012
2,531
670
You don’t need to buy a complete shaft assembly, just buy the shaft tubing. Unless the u-joint assembly is welded to the shaft, most are built so the shaft is just slides in and is pinned. Most dealers carry stock blank shaft in both male and female.
