I just ordered a pat's quick hitch for my MX5100,or there any tricks that I need to know about them? I do know for me changing post hole digger and bush hogs is a chore .
Thanks great idea!!Installation is super easy. I put a set on my B3200 in place of my quick attach from HF. A lot less noise now with Pat's. The HF unit is now on my brother in law's green tractor. One thing to do that many have mentioned if you have multiple attachments. Take a Sharpie out with you and mark the spreader bar for each attachment. This way you can set it to the proper width prior to backing in for a hook up.
Technically, your implements will sit a few inches further back than they would without the hitch. PTO shaft geometry should not change that much but be aware.
I did notice that it took a lot of threads on my top link to hook it up.You might also need a longer top link. The Kubota top links tend to be a little bit short, but the generic top links from TSC work fine with the Pat's QH.
