L3710 hst grinding sound no forward or reverse
5,066
Lightning Truck
9
Tallahassee FL USA
Great! Thank you! I have the parts in my cart and will request a total.
I want to replace ALL the filters and do an oil change(I will run it a little 1st to get the big stuff from work performed). :D Should I get that stuff directly from kubota? Or just cross reference to car quest filters? What kind of oil do you guys run? I use Rotella in my cummins.
Mike
5,066
100% Kubota Filters, Super UDT2 for fluid or if you want to save some $$ and don't mind a little nosier operation from the HST, I run Mystik JT-5 fluid, and I use Rotella oil in it too. ;)
Lightning Truck
9
Tallahassee FL USA
Been a little time since I posted. I got the parts and it went back together beautifully. The clutch disk has no splines. :D
I am ordering this
http://www.ebay.com/itm/301683383082?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
and picking up some oils and hope to be good for a while.
By the way, everything went great until I tried to start it and it would not crank, turns out a little 4 pin connector came loose to the ignition switch when i was tearing it apart. I plugged it in and all is well! Patience is king!
Thanks for the replies and the great help. Especially Wolfman.
Where in N. Idaho are you. I have snowboarded and went to reggae fest at Kellog many times.
Mike
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,110
112
Hardisty, Alberta
I am ordering this
Mike
Kubota must have poorly heat treated a few of those clutch hubs, I've run into this a couple of times. The clincher when you are diagnosing this is observing if the pto also is not turning.
