my bx2360 starts hard even after letting glow plugs work and block heater. have to aply 1/2 throttle to get it to fire, glow plugs test ok, where is the relay for them?anyone have this problem, thanks, snow hog
how did plugs get tested? Ohm meter? Volt meter to plugs once key was turned?my bx2360 starts hard even after letting glow plugs work and block heater. have to aply 1/2 throttle to get it to fire, glow plugs test ok, where is the relay for them?anyone have this problem, thanks, snow hog
ok - that says that you have a voltage TO the plugs.....does not mean that are "good"i used test light off pos.battery term.
i don't have ohm meter, i did disconnect wiring/busbar from plug to isolate,used 12volt testlight to pos. dealer told me this wouldd work?ok - that says that you have a voltage TO the plugs.....does not mean that are "good"
Pop the top connection off of each one - test using OHMs meter - neg lead to ground - pos lead to top of plug - each one separately will/should have a reading of close to 1 ohm , anything above 10 ohms, it is bad.....
ONE that is really bad will have an infinite reading.
report back
