Is there a single "best" thread for lightbars and installation?
Fordtech86
L3200
Aug 7, 2018
4,790
5,623
Pineville,LA
Not much light for my use. I run 2 4000 lumen CREE Led cube lights. I need about 1/4 to 1/2 mile range in the field.
Works for what I need, I’m not saying it’s going to give a 1/4-1/2 mile range like you may need, but it is brighter and wider then factory lights. I have to mow pretty much year round here, so when I get home from work and it’s dark it’s a huge help.
tiktock
225
Plaistow
tiktock
225
Plaistow
Here is my setup after converting all lights over to LED on my B3300SU.
I tied into an auxiliary circuit that has a 20amp fuse. I solder all my connections up to the switch the switch has female blade terminals.
Love that swtich!
I went with boring lit switches:
mrcarnage2
B3300SU
Nov 13, 2017
40
Pullman, MI, USA
The switch was pretty cheap off of Ebay and it's waterproof. I wanted a bigger switch to be able to use it with gloved hands. I was going to put it in the console but I didn't want to cut it up. I plan on installing some other things that will require switches to run some extra stuff on the 3 point. So, I may make a different setup.
