Yeah, I'm pretty certain it's not common rail.
Your right, No it's not
I have seen "electronic" direct injection terminology used in marketing materials though.
Not for the L2501, you will for the L3301, and L3901, about the only engine controls on the L2501 that are even electrical is the starter and fuel stop solenoid.
The engine driven pump is the high pressure pump, not the lift pump.
The lift pump and the injection pump are both fuel cam driven mechanical pumps
Lift pumps are normally electric.
Simply not true, kubota has a ton of models with mechanical lift pumps.
You can hear mine turn on in my MX when you turn the ignition to the glow position.
You sure, they normally only turn on, in the on position.
The L2501 is as Blondie70 said:
Mechanical lift pump
Mechanical Injection pump
Mechanical Direct Injectors
No Common rail
No High pressure pre pump
No Electronics for the injection system.
No electric pumps
