Having some issues with eradic idling, insufficient power. Took electric fuel pump and water separator apart. Fuel pump had a lot of rust particles on magnet. Cleaned. Blew out lines. Ran good for a week then started again. Repeated process. Running good again. Now going to rinse tank as obviously contaminated from slip tank. My question is, I'm wondering if the electric fuel pump is failing because of this? If I remove fuel line to primary filter, there should be a steady flow of fuel coming out and the water separator should fill, correct? Right now neither is happening until I crank engine???? Appreciate anyone's input, thanks!
Sent from my XP7700 using Tapatalk
