OK little history.
I thought one of my tanks had been flushed but still had water mixture in it. My Bad.
I have drained the fuel tank.
Flushed 5 gal of good fuel through it.
replaced with GOOD fuel.
Changed Fuel Filter.
Bleed one cylinder. Started right up. puffed bit of white smoke for a couple of minutes. Ran it for about 4 hours. ran it the next 2 days 4 to 5 hours each day No problem. Stopped at the end of the day.
Next day will NOT start.
Changed Fuel filter again.
Bleed all 3 cylinders 3 times. Fuel running on ground.
still will not Start.
My next option is to change the injectors (never done it)
Read the manual so have an idea.
Question is there a problem reusing the Glow plugs??
Are there any pits to fall into during this process. Rear injector seems to be difficult to get to.
Advice any one!!
Advice any one!!
