DueEast
L2501 HST 4WD
Mar 9, 2021
40
31
Washington
I cut out some old grass and moved some dirt to make room for my new patio and dog run going in on Monday.
Crash277
BX23S
Jan 17, 2021
846
622
Got my tiller parked outside the garage and ready to use. Now I’m trying to decide if I need a quick hitch or a hydraulic tip link. I will eventually have both but only one is in the near future. Leaning more forwards the top link But haven’t found a 16” one in Canada yet. Princess auto has some on sale but the shortest one is 20”.
old and tired
L2800 HST; 2005; R4
...if I need a quick hitch or a hydraulic tip link. I will eventually have both but only one is in the near future...
Crash277, Important!!! The quick hitch makes your implements sit back an additional 4" (or so). ***Make sure you get a top link that will still give you the range of motion you want WITH the quick hitch. Also, remember the PTO driveshaft needs to be able to handle the extra length, too!
Crash277
BX23S
Jan 17, 2021
846
622
Thanks! I checked out the shaft on my tiller when I did the spring maintenance. (It and my snow blower are both brand new and cut by the dealer for my machine) they cut off the absolute minimum they had to IOT make them fit. I haven’t checked my used finishing mower yet. But I do have a length of PTO shaft that the guy gave me when I got the mower and it’s plenty long enough to make 2 longer pieces for my equipment. The snow blower I doubt i would use on a QH, I know I won’t be using a hydraulic top link with it since I need the hydraulics for the chute.
For the top link I only need it for my box blade and drag blade. Maybe I should start a thread and do a poll to see what one everything thinks should be first lol
CKNPRO
L4701 HST
Apr 16, 2021
Alabama
View attachment 52982 View attachment 52983 View attachment 52984 View attachment 52985
Played in the mud this morning. Cleaned out a ditch that was clogged with deadfall trees causing it to overflow from the rain yesterday and started cleaning up a massively overgrown briar/privet patch.
R14’s did very good in the muddy muck, was in 4wd and only had to lock the rear differential once. Cutting brakes also help.
This kind of stuff scares me a little with the R4’s. I would not think twice doing the same thing with my MF 2wd with LBSB Ag tires.
foobert
BX2380
Mar 25, 2021
112
111
Washington
The CO has an intense dislike of these neglected boxwood bushes that someone planted next to the house. The orders were given to make them go away and secondary mission would be to rehome them along the property line fence, but, the burn pile was OK too.
The lil’baby tractor earned it’s room and board and the boxwood was spared from the chainsaw. The root balls came out relatively intact — hopefully they live.
Would have like some more rear ballast for a couple of those, but slow and easy got it done safely.
Reactions: 6 users
pokey1416
Jun 24, 2020
532
738
SW Michigan
Put the snow pusher back on to scare away the snow gods for this next storm.
Fordtech86
L3200
Aug 7, 2018
4,791
5,624
Pineville,LA
Still too wet to do anything here. Did get it out to help with the yearly zero turn maintenance tho
Yes the loader was blocked before I got under it 😁
Bota will get its yearly maintenance next weekend.
forky
L2501 HST 4X4 8N
Feb 23, 2021
254
253
Wisconsin
That looks like led's on the grill guard....is there a chance yo could explain the set-up?
ctfjr
L3800HST
Dec 7, 2009
1,705
1,919
central ct
You are killing me! I just spent a small fortune on 14 boxwoods that were only 14" in diameter :(
ctfjr
L3800HST
Dec 7, 2009
1,705
1,919
central ct
So, if the chainsaw and tractor/chipper do all the work, why 3 hours later I'm beat?
Fordtech86
L3200
Aug 7, 2018
4,791
5,624
Pineville,LA
That was my original install. But stay tuned, I am redoing the set up since I added the back hoe and am going to finish the permanent wiring for the sprayer.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,156
1,558
Western MT
Yesterday, I moved a lot of topsoil 15 to 20 buckets full to a new pile and replaced where it was with random piles of dirt/fill left over from remodel/construction from years ago. I’m getting more used to the feeling of being offcamber in the tractor while still being safe.
Today, I put tubular nylon over my chain that I’m using for a “bridle”. I made it just long enough to drape down a bit into the bucket and attaches to my hooks on each side. After hearing a center hook can bend a bucket, I chose to avoid using a center hook but made a way to pull from both sides.
I haven’t found a hook that will go through the chain I’m using, but I order a 1/4 and hope the pin will fit through. In the mean time, I’m using a typical hook to hook on the center link with a couple of links and a slide hook that I can use with a clevis. That will allow me to use either a chain or nylon strap. Pictures soon.
DaveFromMi
L3901, 5' Bush Hog
Apr 14, 2021
548
463
Indiana
More details, please!
Well.. used a 11,000 tow strap as to not damage the carriage. Found the center of gravity. Lifted it so the legs were about a foot off the ground. Went crossways through an unplanted corn field in a low gear to avoid the lathe swinging. My kid in the picture (his lathe) had a castor kind of box he put under the heavy end. Under that was a makeshift ramp of oak 4x4s and rough cut oak of varying thickness. I got the lathe that far and my kid had an engine lift to pull it through the side door to it's home.
I wasn't sure the FEL would work out for us since the lathe was about 100 lbs over limit. No issues.
The machine is a 1967 South Bend lathe.
Kid wants to do repairs and machine work as a side business.
johnjk
Apr 13, 2017
1,284
869
West Mansfield, OH
Dropped the air pressure on the B1700 and mowed again. Much better. Will finish up mowing today out by the road
foobert
BX2380
Mar 25, 2021
112
111
Washington
Ha! One man's trash ....
We did sell some of the smaller ones that we could barely fit into 10-gallon containers. I wont mention the price -- we were just happy to see them gone :whistle:
